Pump not running when I turn key . 2 wire for the sending unit reads 5 volts . No power reading to pump . Relay checks out OK .
Pulled pump and put power to fuel pump , pump ran . Why am I not getting power to pump . Wires are fine , I traced them all , Ground is good. No check engine lights are on . PCM ? ECM ??
My truck has a dump body so pulling the pump is not a problem .
