ELVISHOTLINE
- Oct 5, 2012
I have a 2000 gmc sonoma that in the last month has a new serpentine belt, bosch plug wires, ac platinum plugs and the brass version of the cap and rotor. It ran great after that. I parked it about a week or two ago. Tried to use it to get to work yesterday and half way to work, the engine light come on. The codes were 101, 300. I have checked some things but donot know where to go. I believe it is running rich causing the misfires. I checked the mass air flow sensor and it is clean. I swapped it with another clean one and got no change. It barely idles.
One tech stated the temp/hot/cold sensor could be failing making it run rich and rough. I only found one on the driver side block area near the exhaust manifold. That one would be for the temp guage and it works. If you would take the time, i really need help because my other truck died inthe morning on the way to work the same day this one started running rich/rough.
