The flasher fuse/switch is constantly "clicking" when I am driving. The only time it stops is when I apply the brakes. I have replaced the flasher with no change. My next effort will be to change out the turn signal switch on the column. Has anyone else have this same problem and solved it by changing the turn signal switch? Can somebody explain to me the root cause of this problem? Thank you
