I just bought a 2003 GMC Sierra 1500 5.3L
I noticed that the digital shift display is so dim that you can barely see it in daylight or at night. I thought it was the instrument panel dimmer switch, but it works the rest of the instrument panel fine. It does go out when you turn the dimmer switch down towards the off position, but on the brightest position you can barely see it. So as you begin to turn it down it goes out way before the odometer display gets dim. Any idea how to get the shift display to increase its brightness other than by the dimmer switch? Thanks for any help you can give me.
I also noticed that the fan display was also very dim compared to the clock and odometer. Any way these two are linked, or is there a way to turn these displays up another way than with the dimmer switch?
