2003 Sierra will not run
Frank.C
I'm having problems with my 2003 Sierra with the 4.3L. It turns over and the the fuel pump works. I've checked the ignition system and it is firing. This started while I was looking for a short due to the battery would run down at times when left parked overnight. I had pulled all the fuses in the box under the hood and the side panel inside the door and re-installed. After doing this now it will only turn over but not start. Any ideas?
