Hello all, I have been trying to fix an electrical issue for days now.
2005 GMC Savana Pro 3500 6.0.
I am getting no ground at the starter relay. If I send power down to starter she starts and runs. I have constant hot at one terminal of relay and "key on" power on another leg just no ground to make the relay "go". I tried the ten minute reset no luck. Anyone know what wire provides ground to the relay and does it come from the PCM? Also a wireing diagram for the ignition switch and passlock system. I think I have a bad wire just dont know what color.
All relays have been tested
all fuses tested
I have no power to the obd port. Is it OBD 2?
Thanks all. ready to take it in to the dealer. I am reading that replacing the passlock system resolves this problem, but Im not a "parts replacer". Kinda like finding the problem.
all fuses tested
