Hi I have a 2005 Sunfire. (It has traction control). I am haveing the front right break sticking on.
I changed the front pads, rotors and right caliper in sept 2009.
This april I changed the right caliper and flex hose because this break seem to be sticking.
I took it to a dealer since and they changed the caliper again, still sticking.
They said it was the $900.00 break modulator vale not working. I picked up a second hand valve and the dealer installed it.
The same wheel is still heating and the dealer said it is a bad valve also.
I find this hard to beleave, 2 valves bad and only effecting the one wheel.
I do not believe it is the wheel bearing due to it does not heat every time.
I can not feel the break holding back the car when on slite grades coasting.
Do any of you have any sugestions.
