johnthecanuck
- Apr 23, 2014
My 2006 Sierra recently started giving me some trouble with the 4wd system. It was taking multiple attempts to get it to go into 4H and the service 4wd msg would display. After it did this for a period of time, it would not switch into 4H at all and only went into AWD and would not shift out of that. Did a bit of research online and decided it may be and issue with the encoder motor on the transfer case, so I went ahead and changed it out. I had to manually turn the shaft on the TC to get it to line up with the slot in the encoder motor but eventually it seemed to mount up properly. When I went to test it out, the selector switch automatically changed to neutral and now won't go into any gear at all. When I press 2H or 4H, I can hear the encoder motor engaging and the light will start flashing for a few seconds, but then it just changes back to neutral with the red light displaying. I disconnected the battery overnight and reconnected it the next day hoping the TCCM would reinitialize but it just did the same thing. Service 4wd light is also displaying. I removed the encoder motor again and reinstalled it, this changed nothing. I am thinking maybe I need to change out the TCCM? I am in over my head here. Any suggestions or help would be appreciated.
