2008 sierra noise at 65+mph
truckie32
Wondering if anyone else has had this issue. When driving on the freeway, if i get up to or surpass 65mph i get a loud vibration noise that seems to be from both A posts. Sometimes its louder than others but the noise is consistent. it has even happen a few times while i was under 65mph. Although i hope no one else has been burden with this annoying issue, if anyone has i would greatly appreciate any insight on what it could possibly be. thanks
Service Information
2007 Chevrolet Silverado - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 2146765 #PIT4172B: Wind Noise Or Excessive Gap At Front Door A Pillar Molding - keywords adjust air alignment appearance body clearance door fit front gap leak left molding noise pillar right roof w/s weatherstrip wind - (Jun 2, 2008)
Subject: Wind Noise Or Excessive Gap At Front Door "A" Pillar Molding
Models:2007-2008 Cadillac Escalade, ESV, EXT
2007-2008 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2007-2008 GMC Sierra, Yukon, Yukon Denali, Yukon XL, Yukon Denali XL
This PI was superceded to add 2008 Model year. Please discard PIT4172A.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some owners may comment of a wind noise or excessive gap between the front door and "A" pillar molding. This concern could be noticed at either the left or right front door.
Recommendation/Instructions:
1. Measure the gap between the reveal molding and the edge of the door 25 mm down from the top of the reveal molding (see picture).
http://gsi.xw.gm.com/image_en_us/gif/000/001/870/1870934.gif
2. If the gap is greater than 7 mm, proceed with the following repairs.
3. Replace and secure all door side bolts with service bolt part # 11609733 (one bolt at a time). These are the bolts attaching the hinge to the door.
4. Loosen the upper hinge bolts and pull the top of the front door header in towards the cab while tightening the top hinge bolts. Close the front door and recheck the gap as per step 1 and if the gap is still 7 mm or greater continue to the next step.
5. Support the door, loosen all door side bolts and lower the door by 1mm and pull the door header inboard while pushing the bottom outboard. While holding the door in this position have someone else tighten the hinge bolts. Close the front door and recheck the gap as per step 1 and if the gap is still 7mm or greater continue to the next step.
6. Remove the reveal molding and install nylon washers behind the reveal up against body in the area shown below. This will space the molding closer to the door edge, but still have at least a 2 to 3 mm overlap of the glass.
http://gsi.xw.gm.com/image_en_us/gif/000/001/870/1870948.gif
7. An additional item that can be completed is to install foam between the body and weather strip as shown below.Note: View to ensure it looks good from a front view with the door closed.
http://gsi.xw.gm.com/image_en_us/gif/000/001/870/1870951.gif
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2008 General Motors Corporation. All rights reserved.
