2011 GMC Sierra starting problems
cruise123
2011 GMC Sierra x-cab SLT Z71 4x4 5.3L
25,500 miles
I've had a few problems over the past month, but today my truck would just keep turning over (like a car without gas). Not a battery issue and I'm pretty sure it's not bad gas. When I finally did get it started a puff of black then white smoke came out for a short period. It seemed to drive ok (no problems idling), gas mileage seemed normal and the truck started right up after driving for 1/2 hour or so.
Does anyone have any ideas? I'm sure it would be covered under warranty but I'm curious. Sensor issues maybe?
25,500 miles
cruise123,
I would like to apologize for the experience that you had with your Sierra. I do understand your concerns with this. Have you had a chance to have your dealer look into this? I would like you to keep me posted and if you have any questions please feel free to contact me anytime.
Thank you,
Stacy GMC Customer Service
25,500 miles
this sounds like a camshaft positioning sensor,
Symptoms of a bad CMP (Camshaft Positioning Sensor)
1. Long start, hard start- this is your issue im assuming,
2. Fuel economy
3. Lack of power.
4. Check engine light.
A trailing edge of the cam signal is received to indicate cylinder 1 on compression stroke by ICM
The next leading edge of the CKP informs ICM to open primary windings and fire coil.
i lead to this cause it turns over, but i would check fuel pressure also cause your fuel pump might be failing causing a long crank, depending on your skillz it can be tested by you or if you feel uncomf you should bring to dealer
