2014 Acadia using oil
nc107
NC
My 2014 Acadia is using up to 3 qts of oil between oil changes. I have read that the vehicle is known for using oil, but this seems excessive. It began at approx 55k miles, now has 77k. I was using a synthetic and changed back as I was told this could help. It does not. Any knowledge to assist in what my options are are appreciated.
nitrojunkie
As I understand it, this is related to cylinder deactivation. My 2010 started sucking oil at about the same mileage as yours, and in similar quantities. Apparently there is a blow-off valve that provides additional crankcase ventilation which only opens during cylinder deactivation. Some people have constructed baffles to go inside the crankcase behind the valve and claim that it radically reduces oil consumption. Others have argued the oil loss is due to excessive cylinder blow-by causing more than expected airflow through the valve and managed to get new engines under their warranty. Others just have their ECM reprogrammed to disable cylinder deactivation altogether. All of these are effective methods of "solving" the problem.
I have just been living with it, but the oil consumption is right about at the limit of what catalytic converters can tolerate... I'm kind of biting my nails on that one.
