I have a new 2016 that I will be getting outfitted to tow behind our RV. I have gone thru the owner's manual to create a cheat sheet of how to hook it up and tow it. On Page 205 are the directions to put the transfer case in neutral. On page 334 are the directions on dinghy towing. The directions for neutral refer you to page 334 - these directions tell you "to keep the key in the ignition in ACC/ACCESSORY to prevent the steering column from locking up". The last direction for the neutral process says to "turn the ignition to the LOCK/OFF" position. I am confused.
Question for Sierra 4X4 owners who flat tow which ignition position do I use while towing?
