3" Body Lift GMC Sierra?
Blackduck90
I am thinking about putting body lift on my 94 GMC Sierra how big of a tire will fit
bd90, i did alot of searching online and asked around when i had the same question for my 99.. the bottom line is that no one was able to give me a firm answer on the biggest tire i could fit..
my best advice to you is to keep your eyes open for other trucks the same year as yours and see what size tires they have...
secondly, if you want to run some numbers on some tires..look at this thread to see how you can calculate a tires diameter based on its size
http://gmcowners.com/gmc-forum/showthread.php?t=10591
compare the diameter to the tire you have on now and see how much space its going to leave between the tire and your wheel well...use some common sense, talk to some tire shops, ask a gmc dealer near you, then decide for yourself.. the good thing is that if you buy from a place where you intend on mounting them, they will tell you if they are not fitting correctly or not..i ordered online, so i had to figure it out myself..
