OK I just got this truck. It was throughing trans fluid from the front. Pulled the trans, pulled the pump. Replaced the front pump seal, pump o-ring and pump gasket. Got it all back together and the leak has stopped but I have some new problems. When u put it in drive and let off the brake it rolls like it has a warped tire and it will not shift into 2nd. If I get the RPMs up and play with the gas it will go from 1st to 3rd. This is the first time I have opened up a trans and I really need some help. Thanks
Posted via Topify using Android
