Hello all, I bought a '93 Sierra for my son a few months ago when he started driving. I am now having the first problem I can't work out and thought some of you guys might have had the same and could help. About a week ago the headlights went out. First I checked wiring, no problem found. Changed bulbs. still no lights. Changed switch in the dash. Still no luck. All running lights have always worked. I was told it was probably the multi switch in steering column, turn signals and dimmer switch controlled on same arm. After searching to buy online or at local auto stores I can only find a column mounted switch, not a multi switch. More searching and I cant find any forum, video or diagram on how to replace and where its located. I don't want to buy if it is not what I need. Also I can gently pull back on turn signal arm, like starting to turn on high beams and at one spot the low beams do come on. I believe this is the problem but I don't know where to start to fix it.
Thanks all
Thanks all
