94 gmc jimmy rough idle good top end?
fishfarm4
94 gmc jimmy vortec 6cyl. has rough idle , i changed plugs,oil,air filter and fuel filter , i cant see sparks at night on plug wires , im lost ,,,
well you may want to finish the tune up replace the pcv and egr valves and clean the throttle body, but i must tell you GM had a tough time balancing that motor, they did smooth it out some with the counter balance shaft but still wasn't like their other motors.
Maybe the wires were not placed in the right firing order. Check your manual. It can also be caused by a faulty vaccuum line.
