ozzman5583
- Aug 20, 2012
it stumbles under load and i have no check engine lights on and idles fine and back fires through intake if i keep my foot pressed i have replace the entire fuel system except the fuel lines and even gas tank and i have replaced cap rotor the plugs wires and control module and idle air control valve and tps sensor map sensor and alternator and battery and ignition coil and blower motor and had the injector re wired to factory state and installed a cold air intake and radiator and temp sensor and knock sensor it has a lifter rattling fuel pump relay has been changed as well and a new converter
