95 Jimmy running rich, rough, and not easy on the wallet, opinions anyone?
Sorry for the mistake, It's a 1995 !!!
First off we only had this GMC Jimmy for a short time, and I am not very mechanically knowledgeable but I do know some things.
Ever since we owned it once in a while while pulling a hill it will act as though it's running out of fuel, even with plenty of gasoline in it, (almost as though it is firing on 3 cylinders) yet around town it's fine.
Also it runs and idles a bit rough, I heard from several people it can do this for a long time but I am just curious as a new owner of this vehicle..It goes through gas like water, and the exhaust is how do you say, very potent, I'll put it that way...
The spark plugs have just been done, but I was told the rear one is a little difficult to get at and "may" have not been properly inserted and if so, what kind of issues can that lead to? All in all, I can honestly say it's a good vehicle, it hasn't yet let us down, but it does run quite rough...
Also, I don't know if anyone could answer this one but, the transmission was replaced before we got it (I'm told it's a Allison transmission if that sounds right), and it seems to like to shift when increasing in speed at high RPMs, almost like it isn't gonna shift, then suddenly it goes to the next gear..It hasn't had a problem yet where it doesn't shift through the gears but it does hesitate a bit first...
Also, at low RPMs in Reverse, it will sometimes die out unless you keep one foot slightly on the brake and one on the gas...But it seems to only do this in Reverse... I was told by a dealership that works on these, that the transmission when replaced actually sorta learns from the way you drive? I don't know if there is any truth behind this, but they think that is why it shifts as higher RPMs...
If anyone reads through my post and thinks they may know what's going on, any details at all are very helpful.
It's a 1995 jimmy auto, and 4x4 with a bit over 150k on it, the rest of the details I don't remember off the top of my head, I'll add on here later.
Thanks
Thanks
