94' sonoma wiper problems
globalmaa
My 1994 sonoma wipers don't work. you can hear the motor slightly but nothing. when you put them on inter you can hear it when you put on high nothing . the washer fluid doesn't work either.
The washer fluid dosen't work because the plastic hose most likely has cracked. This crack usually occurs right near the firewall and cowling. So check that plastic line. It is normally encased in the electrical wire conduit. Very common over time.
It sounds like you need a new wiper motor. That is also fairly common after awhile. Find a good junk yard and go get a "new" wiper motor.
