lovemyburb!
- Jun 14, 2012
Hello all. I have a 94 suburban k1500 sle, 350 motor. 2 weeks ago I noticed my water gauge a little higher than normal. looked at radiator, noticed a pin hole spray of water shooting out towards engine. was coming off water pump. i put duct tape around it and drove it 7 miles a day for 4 days like that carefully keeping 8 jugs of water in the burg for re fills. Took her to the shop had all new hoses,water pump,radiator and cap put in. asked to do timing chain at same time. mechanic said didn't need it. (when picked up)
Drove less than 2 miles from shop, needle way into red, pulled over & called shop. Said a bubble (air pocket) must have formed in the engine,bring it back.my son opened the radiator cap and a fountain of water and coolant flew out. went back to shop, ran fine,added more water.
problem. she had a noise like whine when power steering fliud low,not. Could not press on gas pedal,she would bog down,began stalling. yesterday she wouldn't start,wants to,jump didn't help. today tried to start,white smoke coming from carb, smelled oil stick,gasoilne smell on it.
she ran fine even when had small water leak.never have had a problem with her. oil changed faithfully. she's a beast....what does it sound like? i don't know if i should go to the same shop or ?
thank you
thank you
