Abstrakt123
- Jan 10, 2013
ok so firrst the basics
1995 GMC Sierra 1500
4.3L V6 4X4
___PROBLEM___
so in the past few weeks i have not changed a single thing since the problem has arised.
i have already replaced the Starter, Fuel Filter,Air Filter, Spark Plugs, Water Pump, Every Gas Fuel up I use Seafoam or IsoHeet, new muffler (thrush pipes)
Symptoms.
-it only happens certain days sometimes just for a minute others. it will do it no matter what
-will start to sputter like its not getting enough fuel or bad spark but that wouldnt make sense if it occasionaly does it only sometimes. which made me eliminate fuel pump and spark plugs
- the sputter consists of massive loss of power even sometimes to the point to where no matter how much pedal u lay down it wont even make a noise until u floor the pedal and then it will kick and be totally fine...until you let off the gas again. i mean litereally no sound from the engine not even an attempt at noise( i have a loud muffler so u can always tell) sometimes when u let it try to recover it lets a huge backfire sometimes a couple before it starts moving again.
- somedays it will rough idle weather its warmed up or just cold. and it will sit there and fight with its rpm. starts to idle fine. starts sputter and dipping to low then revzs it self up,. comes to an idle and a few seconds after it will begin to start dipping over and over until it finally will just sputter and die. but it will start right back up everytime. its more of an annoying nuesence then anything
if anyone can help me at all on determining what could be causing this issue without sinking tons of money ( i dont have) to replace parts till i finally find the right one
my opinion.. its either of the following
-Mass airflow sensor
- distributer cap
-loose wire
- oxygen sensor
those are the only outcomes i see any ideas please please let me know i love this truck all to much to want to part ways and give up
4.3L V6 4X4
___PROBLEM___
Symptoms.
- distributer cap
-loose wire
- oxygen sensor
