Vacdaddyt
Just a little confused with adjusting my headlights on my Jimmy. There are the two torx adjusters that move the lenses but what is the other two hex adjusters with the caps on for? I can't seem to get any value from the drivers lo beam. The bulb is on but it has no range. The passenger side is better but the drivers is of little use. I have positioned the jimmy so it shines on the side of my garage and set them both to the same height and the drivers side does not give the same pattern. The lenses do not look filmly or cloudy so I'm confused where to go next. Change the bulb even if it lights? Please help.
