Vacdaddyt
I have scanned some of the posted transmission problems and one of the recommended fixes is oil additive or a boost valve upgrade.
My question is if putting the lucas additive in didn't work will changing the boost valve do it , or is mine too far gone?
When I put it in reverse it hesitates and if you step hard on the gas or are trying to push a trailer it acts like it is chattering or slipping, but if you go easy you don't notice anything wrong. This is a 5TBD model 4L60E in a two wheel drive that I used from an S10 Extreme. Forward it shifts a little hard but goes through all gears but the reverse is weird, note the old transmission was doing the same thing. The motor and transmission have been replaced. The motor is an early model with the upright plug towers and when the transmission was replaced I changed the oil and seals in it. The test port is where? I do not remember seeing one when I had it out.
Sorry for the long post.
If trying the boost valve is a good idea I'm game to do it but was wondering how it is done, the directions I viewed were a little scketchy.
