New to site. looks like a good one. wanted to say hey, and throw out my problem. have a 1500 Z71 reg cab with a problem. the clutch engagement is right off the floor. the pedal feels kinda spongy, but not bad. replaced the hyd system and bled it many times. did bench bleed, and the way the book states. there is no air in the system. I also routed the line to remove any hi spots. the fork is moving good. but its just enough to get the tranny in gear with a little grind. Has anyone had any problems with the fork bending or is the clutch just toast? I dont mind doing the cutch (4X4) but if I look in the hole where the plug is, I can still see the outside of the grooves on the outer edge of the disk. any thoughts would be helpfull.
