My 96 sierra is having issues when gassing on the pedal as if passing someone. It seems to start fine, idle fine, and during normal (easy) pedal depression drive fine. But when you get on the pedal hard its bogging down almost as if it isn't getting enough gas. I have done a normal tune up on it: new oil filter , oil , air filter, fuel filter, plugs, cable, rotor, and cap. Original codes where to many to list however since tune up the only one coming up is p0101 mass or volume air flow circuit range/ performance. I thought maybe fuel pump issues but that would seem id have trouble with starting and idle if that was issue. Any thoughts on this would help. I'm not a mechanic and Dont have the tools to do pressure test and such.
