Burnsside42
I have a 1996 2.2L 4 Banger w/221,000 miles;
Since I have owned this truck (June 2010) it has always had a rough Idle - since then I have replace the plugs, wires, Air temp sensor with harness kit, Purge Valve by fuel tank, clutch kit w/slave cylinder and cleaned the IAC Valve and MAP sensors with Electrical Cotnact cleaner.
Truck idles very poor - and is clearly loading up the cylinder(s) with fuel - if you rev it up after idle for awhile it back-fires. It has coil packs - and being it does not skip a beat under load or driving I see nothing left in the ignition system to be at fault.
Looks like previous owner replaced the cat, o2 sensors, throttle position sensor, cylinder head, water pump, alternator, tensioner, radiator.
What controls the idle/fuel on these trucks? I want to put a new MAP sensor in the truck - but I see no reason for that to affect the idle and the fuel trim @ idle in the way it's acting. Is there a sensor which would control the cold starts? it does start very rough when cold and needs the throttle to be blipped once to keep from stalling on the initial start of the day.
Any help appriciated. Thanks
