96 Savana 4.3l error P0118
Big Darrell
I have a 96 GMC Savana that has been sitting for over a year. Now when I replaced the battery it is very difficult to start runs rough and gives a P0118 error code. I want to replace the Coolant Tempurature Sensor but hopefully someone here knows the location of the sensor. Thank you.
I found the sensor, it is located right in front of the thermostat housing from the top Rad hose. It isn't too bad to change but takes a little wiggling. You do have to move the overflow reservoir and the air cleaner with the hoses. took about 30 minutes.
