97 Sanoma emissions
jdnglo
After I drive for about 20 minutes, the "Check engine light" comes on and stays on steady. could this be a vacuum line? or any suggestions.
Thanks
What do the gauges read when it happens ?
And - Have you checked the coolant / oil / tranny levels ?
All athe gauges read normal and all fluids are good. I recently installed a new heater blowere switch and the temp control doesn't work. That is why I thought maybe a vacuum line was at fault.
on the driver's inner fender, behind the abs module, (gotta love those engineers) is a vacuum conn to the evap canister (at least on my '98 v6)
I saw the broken conn with a small mechanic's mirror, removed the (4) bolts holding down the abs, pulled it gently inward.
I was then more able to get at it.
careful, the vacuum tank conn is a small plistic tit (can I say that?)
luck,greg
