97 sierra lights make truck die
devilr3v
hey guys new on here. I have this 97 sierra 4.3 and i just fixed it up after sitting for 2 years. After i started her up and pushed on the brakes, the truck just drops down to 200rpm then revs up to 3000. Also when I turn on the nightime lamps it just dies. I check the alternator seems fine, change the tail light boards, put new bulbs in, fuses are good and relay is also fine. Any ideas?
Thanks in advance
brake peddle problem is a vacuum leak in the brake booster ( booster has gone bad)
with the engine running have somebody step on the brake peddle while you listen for hissing coming for the booster
not a vacuum leak. it's electrical somewhere. since when you unplug the tail lights and push the brake pedal it is fine.
