'98 GMC Jimmy is not running.?
Kasey F
It's definitely a timing issue. We've checked the cam and crankshaft timing plus the distributor timing and everything is good there. We've also checked the injectors to make sure they're correct since the dealer said that could be it. Any suggestions would be great. thanks!
Yes, the ignition system is functioning properly. We did originally think a coil issue but all of the pieces are working correctly.
