98 GMC Sierra Brake problem?
tooldaddy2003
I just replaced the brakes on my 98 GMC Sierra Z71 and now when I use the brakes the pedal is "mushy" and there is a "ratcheting sound " coming from the front....The brakes stop but it is sort of un-nerving when the pedal is not as stiff as I am used to...Any suggestions or ideas would be appreciated....Thanks in advance
did you bleed brakes or refill master with fluid
type into search box see if you did it right
how to replace brake pads video
how to bleed brake video
did you replace or check rear brakes
