Chaoticdopey
- Dec 22, 2009
ok i have had the code read 7 times now and have replaced the IAC Valve 3 times and the code p0507 keep coming back up as Idle Air Controller "RPM's To High" when i hit about 30mph its as if the cruise control kicks in and idle stays at 1500rpms until i come to a complete stop and it is killing my breaks and killing my gas millage. i have taken it to a couple mechanics and they are stumped i have checked the TPS and its good iunhooked the cruise control hoping that would solve the problem but it didnt. i cleaned all the wires and pluged them back in hard. it seems not to do it as much right after geting off the freeway. any help would be appreciated i will even pay $10 for the best answer that solves my problem just make sure to leave your email address after you post. i'm desperate and have already spent $1300 trying to figure out what it is and do not want to spend any more
ive fixed the vacuum leaks already with no avail i cleaned the TB with TB Cleaner and i also ran some seafoam through the vacuum line which made it run less rough but right when i hit 30mph the rpms jump from 900 to 1500 and keep pulling the truck i can keep my foot off the gas and get up to 60mph without touching the gas people. ive cleaned the mass airflow sensor changed the IAC valve 3 times and ive also unhookd all the wires to all sensors on the engine cleaned themand put them back on tightly and i started the truck with the mass airflow sensor unhooked and the idle did not change at all. i also unhooked the power to the cruise control thinking that might be the problem but it was not. IM STUMPED!!!
