Heypops
I have a '98 Jimmy 4x4, 156k miles, Electronic Climate Control.
Drives great and runs great!!
Recently started blowing HOT air out of AC vents even with AC ON & turned to 'cold' on electronic controls.
Have checked all vacuum hoses and OK. Vent selector works correctly & well, as will blow HOT air out of floor or dash or defrost as selected on dial.
Have read many threads as to needing to change out 'heater blend door or gate', which means taking dashboard off the car.....YIKES !!!!
How do I do get to the 'blend door' or 'actuator' w/o completely removing the dashboard??
Question:
what is best way to diagnose the cause of continuous HOT air from the vents and best way to fix this problem.
Do I need to remove the entire dashboard? Is there a shortcut to the getting at the heater box/actuator?
thanks again to all !!!!
Question:
