98 sierra wont start
top notch
ca
98 sierra wont start have fuel pressure 62-63 and have spark kind of orange change crank sensor,coil, icm, and still wont start do the distributor go bad maybe camsensor thanks
Recheck all the connections the parts you have replaced are on good. The spark should be bluish though and not orange. Try spraying some starter fluid in to your intake tube before the air filter and NO MORE THE 5 SEC. We don't want you blow up your upper intake on your engine. :eek:
If the engine does not start, then it's going to be a ignition issue. If the engine does start then it's going to be a fuel delivery issue, such as the injectors not getting signals to work.
Keep us posted and sorry i am on tour but should be back on late tonight. :(
