Hi All,
To start I have a P0452 code that will not clear. The Jimmy idles ok but falls on its face under load. Been hanging parts trying to figure it out. When I ran codes for the first time it came back with a P0300 random misfire, three O2 sensor related codes which were P0144, P0152, P0147, and the P0452 that wont clear. These codes come back after driving the car for a while. The P0452 code is the EVAP fuel tank pressure sensor low input. I have replaced this sensor as well as plugs and wires, coil, cap and rotor, fuel filter, exhaust gaskets, and MAF sensor. Fuel pump was replaced recently by previous owner. I've read about the catalytic con. being plugged as a possible cause and the MAP sensor. Any help would be appreciated. This is getting expensive.
