used99
Having issues with right rear tail light. When signalling right, the tail light does not flash. The front & dash signal flash quickly as if a bulb is burned out. All 3 bulbs were checked, they work. I was told that the wiring thru the rear side panels to the corner outlet are POOR & prone to corrosion or failure. The column turn signal switch seems fine, but very expensive & labor intensive to replace. One of 2 bulbs work when brakes are applied.
Any suggestions or tips would be appreciated. Can the switch be checked without removing?
Thanks for the help.
