Acadia gone wild.
Swaggywaggy
My wife has had her 2010 acadia for a few hrs now. 3 days ago ithe engine starting missing so I took it to the shop and had it scanned. It came back po305 which could be several things. So I took to the dealer they said it needed 2 oxygen Sensers the ingectors flushed and the plugs changed. Which would have cost around $1000 None of that was covered under the drive train warranty. The truck has 53000 miles. So we went and got it and gonna take to a local shop that I trust that isn't so expensive. But on the way down there all the dash lights went out none of the gauges work and keyless entry doesn't work. So I still have the truck at home anyone have any ideas????
Check the battery
Our acadia started to do weird things when the battery needed replacement around 35000 mi. It is in the floor on the passenger side between first and second row.
The dealer did do the recalls for the airbag which they had to replace some wireing harness. I'm starting to wonder if they messed something up. Also they didn't do a compression check on it also I've read that some have had issues with low compression and had to have engine replaced
Ok took back to dealer they just changed fuse and dash lights came back on. And now the engine light went off and runs perfect.
