do you have a lift or leveling kit on it ,then yes they are high, they are factory set for a stock truck
drivers side should be down and to the right alittle, passenger side down straight ahead
the way I have adjusted then on my vehicles find a dark area on a street , stand in front of one of the lights , look where the other is aimed
do the same for the other before any adjustments
when I say down , not overdone down
then stand a distance in front of the truck as if you are in an on coming car , ask yourself are they right?
maybe put card board in front of one light while adjusting the other it helps you see the change as you adjust
Good Luck
PETE
