Another additive question-Bars leak engine oil stop leak
961kyle
What does this stuff really do, does it work, and is it good to put in an engine?
Don't use it, it will just create issues with your oil flow through the oil passageways and journals. At most use thinner oil to find the leak and replace the seal.
Good luck and keep us posted oh and Restor also works on to sealing minor leaks and is much better then the sop leak you have noted above. ;)
any kind of stopleak is usaully temporary anyway and can sometimes make things worse when it comes to repairing it. your better off just fixing the leak
