back yard body lift
jrobb913
Northern ontario, canada
ok so i decided i am going to make myself a body lift, i have 1" thick peices of metal cut into 3" circles with the center drilled out already, and im getting a set of 20 grade 8 bolts that are 5 1/4"s long, ive been looking i was woundering where the body mount bolts bolt into. ive found the bolts and nuts for the front and rear bumper but along side the vehicle i found the bolts but is it nuts they screw into? if so how can i access them? any help would be greatly appreicated.
Quick question on the back yard body lift, wouldnt you have to make bumper brackets and if you do how do you make them, Im intrested in doin the same but i was wanting my bumpers raised with the body
if you take a look at my pictures of my front bumper then you can see where you must stick the "pucks" to raise up your front bumper, theres 3 bolts per side on the front bumper
