I posted this once and it never showed up. I have a 93 sonoma 4.3 liter 2 wheel drive. The battery drains very quickly. I hooked a test light between the neg cable and the neg post on battery. The light came on pretty bright. So the first thing i did was take wires to alternator loose. the light went out. Then i noticed if i touched the two leads that came off of the same terminal on the alt. the light would shine bright again. What i need to know is where the two wires that come from the same lead go to. The one wire goes to the positive lead. If i touch just this wire to the battery the light stays out so i think that means the alt. is not grounded out. If i hook the other set of wires on there with the wire from pos battery post light is back on. touching the two wires that came off the same post on alt. together light comes back on. What i need to know is where the other two wires from alt go to. If you need more info let me know. Thanks for any help.
