Battery Replaced..Need to Reset AC Vents
Cobra1365
I have an 03 Sierra and for the second time, I've had to replace the battery (98,000 miles). Now, my vents are out of sync again and only blow through the defrost. Last time this happened someone sent me a procedure to pull fuses in sequence...like a bonehead, I lost those procedures.
I've tried the key on/ engine off for 45 secs and the key on/engine on for 2 mins...no joy.
Any ideas?
Put one side on AC other on heat run truck turn off. Then do the opposite. run truck turn off after 3 mins. Then both on AC run truck should work for you.
