hey everyone. Is there sumthn i'm doing wrong? I replaced my front calipers, sway bar endlink, had rotors turned, and replaced the pads. Put everything back together and bled the brakes by opening the valves on top of the calipers. Unfortunately, i pumped too many times and emptied the reservoir. Now, i've got a bunch of air in the system. I then poured a couple of quarts in, but the brake pedal simply refuses to stiffen no matter how many times i pump it. Is there any other way to bleed the brakes on a 95 jimmy other than the valves on top of the calipers? thx.
