Brake help
Jim624
a 2005 GMC sierra 1500. I have replaced the Master and slave cylinders, new pads, front rotors, pads, calipers ….all new new… However, after bleeding all four wheels, many, many times I still have no brake pedal. (I did not bench bleed the new master) I am at a standstill. Could it be the ABS ?? There are no bleeder valves on it. perhaps I have to much air in the system ?? Any help would be appreciated
Phatocaster
When you bled the brake system did you start with the passenger rear, drivers rear, passenger front and drivers front?
