I have a 97 gmc jimmy. The brake booster went out on it. So I replaced. in doing this I followed all procedures...the rod length is the same as the old one. Because I didn't even open up the hydraulic system I shouldn't have to bleed the brakes but they were going to the floor now...So decide to install a new master cylinder....I bench bled this and followed all diagnostic instructions to a t.. The problem that I am Having is that when the car is off it has brakes but when you turn it on the pedal goes to the floor. all the brakes are good. and it has rear drums.( the wheel cylinders are good and the shoes are adjusted out) any ideas what could cause this problem?I am going to also add the car stops fine but it is as if there is no reserve pedal it goes to the floor.....it has abs as well and i was told you have to use a scan tool to bleed this if you suspect air of being trapped inside the unit
I have replaced this with a new one a still the same problem........
