Brakes. Help
Doob
03sonoma 160000mi. Rear wheel drive 4.3 engine. I’ve bled the brakes 3x and still pedal goes to floor only with engine running. It has abs. So I’ve even used a scan tool to remove air from abs pump. So it has a porportioning valve. Master cylinder is good. No visible leaks. It’ll pump up with engine off but goes straight to floor when started. I started at rear right wheel I saw a guy that said to start at lt front then rt front. Then do back brakes. I bled the abs before I did the wheel though. Can you help plz. Thanks a lot.
