Broken bolt on rear diff
961kyle
Changed oil in the rear diff. While taking off the cover one of the top bolts broke off. I think it was weak before i started because it didnt take much torq before it broke. Its one of the bolts on the top side so im hoping it wont make oil leak, i put on a new gasket. Has anyone had this problem or does anyone think this will be a major problem?
If you used RTV silicone gasket maker, you should be fine since there is no internal pressure on the rear end. If you used a pre made gasket, you may have some oil seeping through. The missing bolt will may not have enough pressure in the two surface to have the gasket form a seal between the two parts. keep you fingers crossed and you may be lucky that there is no oil seeping through the gasket. :rolleyes:
You can buy the bolt extractor from most Auto Parts store and it's simple to use. All you need is a drill, hammer and ratchet set to remove the broken bolt so you can replace it. Good luck and hope this works out for yha. http://homerepair.about.com/od/interiorhomerepair/ss/screw_extractor.htm
