Can i put a cool air intake in a 2003 GMC Sonoma without it saying check engine.?
Ddille
i have talk to a few people and they said the computer would say that it is getting too much air and then the light would turn on.
Yes you can put one on and it will not cause the light to come on. I did it on my 98 and have not had a problem.
The best cold air intake i know of is the stock air box you have. Open up the air box and remove it from the engine bay, there is only one bolt holding it in.
Notice the front of the air box having a restriction tube, the best mod you can do is to cut the front of the air box open where the tube is. Make sure you don't cut the top of the box where the air filter seals to, with the tube out. It's wide open to take cold air on from the air vents behind the head light and keeps the heat out from the engine and radiator. ;)
It's free to do and take about 30 min to do, you can use the paper filter or a stock K&N air filter if you like. You will not notice any difference in performance unless you tune your PCM. http://www.pcmforless.com/ You will notice a different sound from your engine and exhaust, when you cut the front of your air box out below the mount it get's really loud about 1750-2000rpm and up of air getting sucked in. Send a PM to http://gmcowners.com/gmc-forum/private.php?do=newpm&u=9224. He did his with a stock exhaust system and he's happy with it.
Good luck and hope this helps. ;)
I'm thinking about doing this with my sonoma. But this is probably a dumb question, what's PCM? Do I have to take the truck to a shop to program it? If so what do I tell them at the shop? If it doesn't need to goto the shop how would I progra it myself? Any special tools needed? Sorry for all the questions. New to working on my own vehicle besides oil changes and masic maintance.
Fipk
I added fresh air intake performance kit to 2 trucks I have and got better mileage and power. Just a little more throaty sound at full throttle.
