I have a 2013 5.3 Sierra and my check engine light comes on during idle. I have a code reader and it says the truck is running lean. I can reset it, but it will come back later on at idle. If I am driving it, it will never come on. Suggestions?
Thank you. I am at 145k on mileage and need to replace hoses. A guys said it could have a vacuum leak. I will get that done.fuel pump not getting enough voltage to produce the pressure the injectors require when engine is idling,
dirty injectors,
poor quality gasoline
weak fuel pump
i don't know if there is a fuel filter on your truck, my 2011 does not have an external replaceable filter
PETE
