Shovin4Money
- Nov 2, 2011
2007 gmc Sierra new body style extended cab.
Just recently I got it checked out at autozone and it said there was a problem throttle position sensor or brake position sensor. Anyways my stock remote start won't work when the check engine light is on. I figured that out when the code was cleared but it came back. I found the throttle position sensor. Can I change the sensor itself or have to change the throttle body as well? The sensor has around 6 clips. I have read older gmc's have the tps riveted into the throttle body.
